Forums >> Revit Building >> Technical Support >> wall foundation issues
7 Posts No Rating |
HI,
I created a wall foundation by choosing a wall I had, it works fine except that in an opening it has that was created trough editing the profile the foundation show on the top of the opening. as shown in the image
is there a way to change it to not appear in openings???
This looks really strange. I would think you want a foundation under the glass portion of your wall so shouldn't your wall extend down som and extend under the glass?
7 Posts No Rating |
the thing is since the wall has that opening, the sliding door is in the back of the wall. so I have an opening and the foundationa goes up automatically. so no, i do not want my wall to go down more.. i guess
This is not a perfect work-around. I hate work-arounds. If you want yo use edit profile to make the opening. you can create the opening as an inner region and leave a 1/128" space between the top of the footing and the bottom of the wall.
7 Posts No Rating |
Tanks... I also found that another work around it was to split the wall. that worked find.. a bit annoying though
Split Region Wall Foundation Issues |
Wed, Jun 1, 2011 at 5:36:25 PM
foundation wall tag |
Wed, Jul 22, 2015 at 1:22:24 PM
WALL FOUNDATION CORNER |
Tue, May 5, 2015 at 10:17:12 AM
Foundation Wall Family Edit |
Mon, Apr 20, 2009 at 5:53:01 PM
Wall Footings and Foundation extrusions |
Wed, Jun 8, 2016 at 7:55:54 AM
Members: | 2099158 | Objects: | 23170 | Forum Posts: | 152292 | Job Listings: | 3 |
