51 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Problem with glazing and wall alignments
Thu, Jan 24, 2013 at 9:52:47 AM | Problem with glazing and wall alignments
MEBDesign
I'm struggling with something which I have tried to explain in the attached image. I have an element of glazing sitting on a plinth which connects into a wall. The problem being that the glazing is not sitting flush with the wall it meets. The orange line representing where the glazing wants to finish instead. In the diagram if I drag the 'grab handle for the glazing to the blue line (where I want it to sit) then it just jumps back to the same position. I seem to come across a few instances like this, is there something funamental that I am doing wrong? Some setting I'm not ticking?
Thanks for any replies.
Simon
Thu, Jan 24, 2013 at 9:59:17 AM | Problem with glazing and wall alignments
4 Stars: 203 Votes
If this is what i'm thinking the problem is in the wall, try to "Disallow Join" then drag BUT I believe you don't have wall enough to do that...
Thu, Jan 24, 2013 at 10:07:08 AM | Problem with glazing and wall alignments
MEBDesign
It wouldn't allow me to move it directly to the position I wanted but would on the second move of the handle. So that is sorted now thanks, what is the 'disallow join' option actaully doing?
Thu, Jan 24, 2013 at 10:10:47 AM | Problem with glazing and wall alignments
4 Stars: 203 Votes
From your HELP menu: http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0328-Build_th328/0330-Architec330/0331-Walls331/0336-Modifyin336/0339-Wall_Joi339/0346-Allowing346
Thu, Jan 24, 2013 at 10:17:00 AM | Problem with glazing and wall alignments
MEBDesign
My bad, should have checked that, thanks though!
Custom window family glazing problem
Fri, Mar 27, 2009 at 2:26:31 PM
Can't delete Glazing or System panels in Revit Structure
Wed, Apr 17, 2013 at 9:57:52 AM
Curtain system > glazing panel matherial
Mon, May 28, 2012 at 1:02:15 PM
Changing Glazing
Wed, Feb 24, 2016 at 9:09:19 AM
Tell me again how to make "sloped glazing" look like metal roofing?
Wed, Jun 11, 2008 at 9:43:35 AM
Page generation time: 2.5520
