112 Users Online (111 Members):
Forums >> General Discussion >> Revit Project Management >> The option to create Wall section not showing up, only building section.
5 Posts No Rating |
When I want to create a wall section view the option isn't there. I can only make a building section or a detail view. The wall section catagory isn't showing up on the tree either. I have other projects in 2013 and don't have an issue. I tried copying a wall section from another project but it won't allow me. Any ideas?
![teafoe5 Avatar](user_avatar/204239.jpg)
![4 Stars: 47 Votes](/images/stars_4.gif) |
There is no "wall section" or "building section" tool it is simply SECTION on the View Tab in the Create Panel. You just drag the length of the section to the size you want. If you are talking about the type then you need to click on the section and edit the type and duplicate the type and rename it Wall Section.
5 Posts No Rating |
Thanks, I didn't know you could create different types of views. I thought they were hard wired.
Wall Section won't show in both plan and building section |
Wed, Jan 29, 2014 at 6:52:25 AM
Create Wall Section Type |
Thu, Jun 30, 2011 at 3:58:23 PM
Callout: Detail view vs. Building section RAC 2008 |
Mon, Sep 24, 2007 at 2:05:38 PM
Building section callout visibility in intersecting views |
Mon, Jun 16, 2008 at 12:40:58 PM
Building Section callout not showing in plan views |
Fri, Mar 11, 2016 at 3:41:54 PM
Members: | 2017094 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
