68 Users Online (67 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Groups ungroup when dimensioned.
Wed, Jan 23, 2013 at 8:50:42 AM | Groups ungroup when dimensioned.
OzRob390
Hi!
First post so here we go.....
We're using groups for ceiling mounted electrical symbols like heat detectors, extract fans etc. but when we place them on a plan and then put a setting out dimension to them from a wall, the group 'ungroups'. The following error message is diplayed:
'Changes to groups are allowed only in group edit mode. Use the Edit Group command to change to all instances of a group type. You may use the "Ungroup" option to proceed with this change by ungrouping the changed group instances.'
I've searched previous threads but haven't come across this particular problem. Any help would be much appreciated!
Rob
Thu, Jan 23, 2014 at 5:54:12 PM | Groups ungroup when dimensioned.
raja15
Hi OzRob390
I just quickly tried out this method to try and understand why your groups are "ungrouping" and I had no dramas with the dimensions or the groups. (refer to attached)
The rectangle in the middle is a simple detail group comprised of detail lines and a filled region, the walls are simple 3D revit walls and the dimensions are standard.
Is it that you are using model groups instead of detail groups perhaps?
Fri, Jan 24, 2014 at 7:16:36 AM | Groups ungroup when dimensioned.
You can dimension to any element is a group but YOU MUST ACCEPT THE DIMENSION!  If you change it, you are trying to change an element in the group.
Previewing walls forces group ungroup then crashes program (2010)
Wed, Nov 3, 2010 at 9:57:14 AM
Revit 2014 accidental ungroup / exploding groups
Tue, Aug 26, 2014 at 9:21:36 PM
How to edit family parameres inside a group?
Thu, Aug 25, 2011 at 12:21:16 PM
'Ungroup' causing fatal error in Revit Architecture 2011 [ 1 2 ]
Tue, Aug 24, 2010 at 4:03:21 PM
15
Groups and Phases
Thu, Jan 29, 2015 at 10:45:27 PM
Page generation time: 0.2773
