Forums >> Revit Building >> Technical Support >> Locking symbolic lines to a wall face (electrical fixture)
32 Posts No Rating |
Hi all,
Another probably elementary question for you all.
I am just doing some 2d families and want to align the shapes (symbolic lines) to the wall face so that they 'stick' to the wall, no matter how thick the wall is. I am using the Metric Electrical Fixture wall based template but can't seem to align geometry to the wall face, especially circles for light switches.
Can anyone help at all? I have googled the subject, but nothing relevant has come up.
Many thanks,
Lee
Edited on: Wed, Jan 23, 2013 at 6:06:29 AM
If you can, use a face based template.
If you use a wall based, add a reference plane away from the face of the wall and build your family around that. Then add a dimension from the face of the wall to that RP. Click on the RP and change that dim to 0 and everything should now work.
Thank you, as ever, WWHub.
I have done what you have suggested but am still struggling to get circles to 'lock' the the reference plane. I move via quadrant but never get a padlock. Am I doing something obvioulsy wrong?
Thanks.
Think I may have figured it out --- I made two half circles and by moving the via end point of one of the arc, this seems to work, I still don't get the padlock, but it moves in relation to the RP.
Just something to remember.
You don't always need padlocks because Revit works a lot with association. That is why you were having problems. What you had originally created was associated with the center of the wall rather than the face. By using a RP, you can assure it does not do that. Secondly, the RP needs to be there before you add anything. Remember - Revit means you have to plan ahead. RP first then other elements. No need most times for locks.
This is superb advice, WWHub. Thank you very, very much.
Another way:
Create the CIRCLE (symbolic line), move the circle to the face of the wall then create a dimension (face of the wall to the center of the circle) and LOCK
Thank you Typhoon, this is great advice too.
symbolic lines |
Thu, Jul 13, 2006 at 8:15:41 PM
Symbolic Lines within wall based family. |
Tue, Feb 5, 2008 at 5:41:27 PM
Symbolic Lines in Profiles. |
Fri, Nov 1, 2013 at 4:47:54 PM
Symbolic lines in elevation |
Thu, Jan 10, 2008 at 7:12:53 PM
Symbolic Lines and Model Lines |
Wed, Mar 22, 2006 at 12:52:17 PM
Members: | 2056509 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
