74 Users Online (72 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> The Studio >> Creating (length) adjustable SAUNA benches
Tue, Jan 22, 2013 at 5:31:55 AM | Creating (length) adjustable SAUNA benches
methosan
Hello,
Short time reader, first time poster.. I started studying Revit end of November to complement my existing skills. The learning is self-guided and at your own pace.  I breezed through the step-by-step directions that the institute was able to give me, but beyond that I am on my own to continue my learning curve.  They recommended that I continue designing something I was already familiar with, which was my old profession: Designing and building highly custom sauna rooms (all over the United States).  I am myself in Europe now.
I am interested in learning to create fully parametric family objects that are realistic looking and can be adjusted in length and angle.  I would (eventually) have 2-3 bench profiles at 2 different depths for each, with the length and end angles remaining adjustable for each individual room.  I intend to keep selling and designing these rooms for my clients despite not getting to install them.
I have 2 tasks at hand but I want to cover the benches first.  I will have benches with either 2x2 or 2x4 tops, atop 1x3/2x3/2x4/4x2 frames/supports. I want to be able to have each board separate from each other, like they are when built, so that if I place light fixtures under the benches, the light would shine through the gaps (even in the rendering).  I also have Chief Architect X1 which I haven't touched in years, and one guy had done some amazing blocks and renders for saunas, but so far I haven't seen anything good in/Revit.
So this first bench profile is 2x4 ladder frame with 2x4 tops running the long-ways, with an 2x6 fascia. Boards are spaced 1/2" apart as well as from the wall.  Blocks of 1/2" x 1-1/2" x 3-1/2" where the ledger screws to the wall allows me to keep the 1/2" drain gap/ventilation/spacing gap against the wall. I would create different families for the various depths, like with this Upper Bench, it is 2'-2" from the wall to face; that shouldn't adjust in Project.. just the length and angle of end if it terminates at an angled wall or another bench in an angle.
I understand that as the bench grows or decreases in length, it will affect the number of blocks required underneath in the ladder frame, though they are secondary.  They do affect the lighting greatly, so I would love to see them work properly, but I do not know how to do it. Some kind of an array command to get blocks spaced 2'-0" apart underneath?  Support to the floor/lower bench is of little concern to me at this very moment.
Does anyone have good suggestions? The youtube videos run gamut from furniture to all kinds of other items, but this is a little unique, I think.  Also, some of the videos are hard to follow and with only one screen at school, difficult to utilize.  Also, since I am in Europe, I can't well walk into a bookstore and expect to find the/a Revit Bible, particularly in English (it is my third language but it was my primary language the last 17 years and all of my drafting experience is with it).
I am attaching a few files.. the bench in family as I have made it thus far; a floorplan of the sauna I wish to 'Revit'; and a wireframe isometric I made in Acad to try and show what is going on (before I got this far with RFA); as well as a picture of a room I built utilizing this construction style (which is what the next client wants, too).
Next step after the benches, should I ever master them, would be creating T&G paneled walls, horizontal and vertical, where the small V-groove was clearly visible.
Thanks for any help/guidance you can afford.
Edited on: Tue, Jan 22, 2013 at 5:38:44 AM
Wed, Jan 23, 2013 at 7:47:15 AM | Creating (length) adjustable SAUNA benches
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You may want to check out the Creating Custom Revit Families book
http://www.littledetailscount.com/index.php/products/revit-family-bundle-11-ebook-creating-custom-revit-architecture-2012--2013families
Or the Autodesk Revit Families Guide
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13126315&linkID=9243099
Sat, Jan 26, 2013 at 10:05:43 AM | Creating (length) adjustable SAUNA benches
Alvaro8100
I'm totally agree with teafoe5.I have to read out this(above you mention).This guide contains conceptual explanations, hands-on tutorials, and reference information.This will be helpful for you.
pool accessories
Adjustable length in component families
Mon, Jul 26, 2010 at 1:45:33 PM
Creating a New View Title that is adjustable in the project
Fri, Jul 31, 2015 at 11:32:20 AM
adjustable stem length on light
Mon, Jul 26, 2010 at 3:18:48 PM
Filled Regions - How to make them show in all views
Thu, Nov 21, 2013 at 3:37:42 PM
Creating a Beam Family Where Each Type has a Determined Length
Wed, Aug 31, 2016 at 11:55:27 AM
11
Page generation time: 0.7023
