89 Users Online (88 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Castellated Beams
Mon, Jan 21, 2013 at 5:19:47 AM | Castellated Beams
bramblestown
I am having trouble producing a castellated beam in Revit 2013. When I load the castellated beam family it gives me three options and none of these are the one I want. when I duplicate and try to 'edit type' I can't get it to give me what i need. The beam I'm trying to produce is a 915x229x113 castellated beam which is produced from the original beam of size 610x229x113.Any help would be appreciated on this?Michael
Mon, Jan 21, 2013 at 10:03:58 AM | Castellated Beams
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"I can't get it to give me what i need"  Why not?  Do you get an error when you try?
When you duplicate the type you should be able to put in the specifications needed for the dimensions.  Are you using an OOTB family or did you find this family somewhere?
Mon, Jan 21, 2013 at 10:37:49 AM | Castellated Beams
bramblestown
Thanks for the reply
When I duplicate and edit type, in the Type properties on the Dimension or Structural drop downs I expect the beam the castellated beam is formed from to be there in the dropdown list. I'm not sure I have to put in all the web and flange thicknesses etc. This doesn't seem right.
I don't know what OOTB is! The original family comes from within the package.
Mon, Jan 21, 2013 at 10:46:21 AM | Castellated Beams
bramblestown
Mon, Jan 21, 2013 at 11:04:06 AM | Castellated Beams
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
OOTB=out of the box.
When I insert the OOTB castella beam all I get is CB18x22 and CB21x22/26 I am not sure what the difference between that and the 915x229x113 is.    If you go to edit type, then duplicate you can name it whatever you want and it will appear in the properties drop down list but you will still need to change the dimensions to what you want it to be.  "I'm not sure I have to put in all the web and flange thicknesses etc" If you don't put the dimensions of them in how do you think Revit knows what you want it to be?
Mon, Jan 21, 2013 at 11:10:42 AM | Castellated Beams
bramblestown
Mon, Jan 21, 2013 at 11:13:29 AM | Castellated Beams
bramblestown
ok thanks I'll have a look at that tomorrow morning.
Tue, Jan 22, 2013 at 4:43:21 AM | Castellated Beams
bramblestown
ok I started from scratch. The two types I had OOTB were from the UK families CB530x32.9/39 and CB460x28.3.
So I 'Edit Type' the CB530x32.9/39
Then 'Duplicate'
Call this one CB915x229x113
There are three areas to be then filled out in the Type Properties
Construction
Structural
Dimensions
I fill in the dimensions list as I know most of those. I don't know what K1 and r1 are.
The 'structural' and 'Construction'list is confusing, what goes in here.
Why can't the program just give you a drop down and you pick a beam size the castellated beams will be formed from. That makes more sense to be than fillling out flange and web thicknesses.
Anyway I fill out these as best i can but the outcome is not the castellated beam I want which is no surprise to me as i don't know what's to go in half those boxes.
Wed, Jan 23, 2013 at 7:42:47 AM | Castellated Beams
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
The program doesn't give you a drop down of those sizes because it only has 2 programmed.  Why it only has 2 I do not know.  I also do not know what all of the dimensions in the type properties refer too.  If it is not working with the dimensions you have you may want to check out ARCAT.com to see if they have any BIM models of Castellated Beams, or do a google search to see if you can find what you are looking for.  Sorry that is all the help I can give you.
Wed, Jan 23, 2013 at 7:55:26 AM | Castellated Beams
bramblestown
Thanks for replying anyway. I will go have a look at ARCAT.com and see what I can find.
Thanks again
joining two beams
Fri, Jul 6, 2007 at 12:03:11 PM
making beams dotted and upstands
Tue, Jun 3, 2008 at 3:50:25 AM
Beams that are copied are invisible, while beams placed can be seen??
Sat, Jan 20, 2007 at 9:53:44 AM
RVT2015 - Insert steel beams over doorway
Tue, Apr 25, 2017 at 9:06:48 PM
Battered ends of L-Beams
Thu, May 9, 2013 at 12:32:51 PM
Page generation time: 0.5520
