73 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Layer materials on walls
Sat, Jan 19, 2013 at 6:08:56 AM | Layer materials on walls
FITZT70
Let me start off that I'm a novice Revit user mainly because of my AutoCAD addiction.  Now I'm in a position to do some rather large models and I'd like to have some opinions on how to apply finishes to walls.
The models I will be making are of existing facilities where we will be mapping finishes, moulding, base and trim on wall and ceiling surfaces.  These models will be then used for rendered views and studies of various design alternatives.  Basically I'm beginning to make a mass as-built model.
Revit wall types generally have finishes on both sides but in reality most walls vary so much it doesn't seem to make sense making wall types for each scenario.  I've seen this handled in two different ways:
1.  Make a wall that is center justified and makes up the core of the wall.  Then after having the rooms made up, make "one sided" walls that are left/right justified with the various finishes, (e.g. gyp. bd with paint and rubber base, gyp bd with wall covering and stone base).  The "one sided" walls will be aligned to the core walls and will vary by room.
2. Create regular wall types as with finishes on both side and then add components on top such as the finish, moulding but editing the face of the wall.
My goal is to have 3D rooms that I can virtually strip down and refinish to show several alternates.  I'd also like to be able to to material take-offs for budgeting and create area calculations of all various types of rooms.  Can you see benefits and or pitfalls of either approach?  Any success stories to share?
Lastly I talked my boss into getting Revit Design Suite Premium so I'm hoping to use Navisworks Simulate to do fly throughs of the model.  Has anyone out there used it?  Is it worth investing the time?
Sun, Jan 20, 2013 at 12:42:53 PM | Layer materials on walls
3.5 Stars: 401 Votes
There are some additional tools you are missing.
  1. Revit's wall can have different materials on different faces - they don't have to be full thickness but layers just like you build the wall.  Exterior material - structure - interior material.
  2. You can paint a wall face to change the exterior finish.  This is a fulkl face paint.
  3. You can split a wall face to paint in limited areas.
  4. If you do have different materials room to room, then I suggest thin veneer walls for those areas.
Mouldings and base are best applied as sweeps.
Starting as a mass model might sound right but walls by face are hard to manage and revise.  If walls are vertical, then I would model walls and forget the mass.
Walls - Paint Layer
Tue, Feb 12, 2013 at 7:59:06 AM
DWG export, separating materials..?
Thu, Apr 18, 2013 at 5:02:35 PM
Problem with Exporting to dwg with multiple layers for use in 3D Studio
Mon, Dec 13, 2004 at 5:21:21 AM
wrapping wall materials
Thu, Aug 14, 2008 at 4:40:22 PM
What's the Point of the Membrane Layer
Mon, Nov 11, 2013 at 5:11:55 PM
Page generation time: 0.6474
