151 Users Online (149 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Question about sketch Mode
Thu, Jan 17, 2013 at 12:15:12 AM | Question about sketch Mode
revituser24
revituser24 Avatar
3 Stars: 1 Votes
I have Revit architecture 2012 student version.  Sometimes when I want to use sketch mode for creating floors, cielings and roofs, the sketch mode commands do not appear on the ribbon. It seems like I have to open a new .rvt file to be able to use sketch mode, and even then it seems that I can only use sketch mode one or two times per file. Can someone let me know what if anything am I doing that prevents me from retrieving sketch mode?  For example, when I select the floor tool command, the sketch mode commands do not appear on the ribbon.
Thu, Jan 17, 2013 at 8:12:32 AM | Question about sketch Mode
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"when I select the floor tool command, the sketch mode commands do not appear on the ribbon."
What does happen when you go into sketch mode?  I am not sure if there are any updates or hot fixes for the student version but you may want to look into that also.
Thu, Jan 17, 2013 at 5:40:21 PM | Question about sketch Mode
mansell5
3.5 Stars: 4 Votes
try turning off hardware acceleration.
i had similar issues (ribbon not filling in unless u moused over it), and turning off hardware acceleration solved this issue.
find under :-   the big R| options|graphics
regards
geoffm
Thu, Jan 17, 2013 at 6:34:57 PM | Question about sketch Mode
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
http://revitclinic.typepad.com/my_weblog/2012/09/revit-ribbon-appears-completely-blank-for-some-tabs-.html?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+typepad%2Ftherevitclinic+%28The+Revit+Clinic%29
Filled Region Sketch Mode
Tue, Nov 17, 2015 at 1:28:35 PM
RST 2012 RIBBON IS ACTING CRAZY . . . while in sketch mode
Wed, Apr 11, 2012 at 3:36:07 PM
Fatal error when in any type of sketch mode
Wed, May 16, 2018 at 11:28:44 AM
Sketch mode will not start
Thu, Oct 16, 2014 at 10:38:47 AM
Floor Sketch mode
Fri, Dec 3, 2010 at 3:46:31 PM
Page generation time: 2.3131
