51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> Titleblock Date Issue
Tue, Jan 15, 2013 at 7:41:07 AM | Titleblock Date Issue
KimTROJB
I have had to organize my titleblock revisions by date and in ascending order so the latest revision is on top.  I am now running across the issue that a revision with the new year is showing up at the bottom of the revision schedule.  Does anyone know how to fix this?
Tue, Jan 15, 2013 at 8:16:31 AM | Titleblock Date Issue
3.5 Stars: 395 Votes
The order is there for you to set:
Tue, Jan 15, 2013 at 8:22:59 AM | Titleblock Date Issue
KimTROJB
Yes, thank you.
But because of a sub contractor I had to change that to Revision Date and in ascending order.  Now when I add this year's revisions, they are showing up at the bottom.  Revit is seeing 1 (January) as coming before November (11), even though it's 1/2013, not 1/2012.
Tue, Jan 15, 2013 at 10:32:01 AM | Titleblock Date Issue
jmagruder
2.5 Stars: 3 Votes
When you make revisions are you using revision clouds and the Sheet Issues/Revisions box or are you using a schedule?
Tue, Jan 15, 2013 at 10:38:30 AM | Titleblock Date Issue
KimTROJB
Revision clouds.
Tue, Jan 15, 2013 at 10:39:31 AM | Titleblock Date Issue
Tristanc
3 Stars: 1 Votes
I find this issue with simple folders in windows, the way I resolve it is to put the year first. e.g. 2013,01,15
als know as ' Gregorian big-endian, (Year - Month - Day )' ( according to wikipedia )
Not a revit solution but a solution Smile hope it helps.
Tue, Jan 15, 2013 at 10:41:19 AM | Titleblock Date Issue
KimTROJB
That does thank you Smile
Sheet Issue Date Format
Tue, Apr 3, 2007 at 5:05:49 PM
Current date in formula on titleblock
Tue, Oct 9, 2012 at 8:09:59 AM
Issue date vs Revisions
Tue, Oct 14, 2008 at 10:10:36 AM
date and time on titleblock
Tue, Apr 11, 2006 at 8:19:46 AM
remove time from date/time stamp in titleblock REVISITED
Thu, May 14, 2015 at 6:54:58 AM
Page generation time: 2.5787
