65 Users Online (64 Members):
Forums >> Revit Building >> Technical Support >> Parametric Arc Sweeps - How to Bypass the Concentric Arc????
29 Posts No Rating |
Hi, I running 2013
I am creating a string of lights which will hang from a ceiling. Think party lights or Christmas lights. I want this string of lights to be faced based. (More Flexible) I want to be able to adjust the depth which the center hangs from the ceiling. (The Radius) I also want to be able to adjust the length of the arc. I can only seem to apply parameters to one or the other, length OR depth. If I try to create both parameters, I am greeted with the error of trying to overconstrain my model. This is due to the arc being set to concentric. How can I bypass this? I want to change the radius and the length of arc from within my project and as instances, typically.
Thanks!
![dingohot Avatar](user_avatar/155924.jpg)
![3.5 Stars: 5 Votes](/images/stars_3.5.gif) |
Arc is far more complicated to handle with parameters comparing with straight lines.
it has radius, length, and center point and they are closely related each other.
So you have to use formula to handle arc lines somtimes. (ex. Pythagorean theorem)
and here's and example..
http://youtu.be/twLRmd0gXfE
want more?
You can get more tips at Enjoy Revit |
Divide arc by length |
Fri, Sep 7, 2007 at 6:17:46 PM
ARC LEADER NO TEXT |
Thu, May 2, 2013 at 10:36:04 AM
Arc Walls with curved top? |
Thu, Aug 7, 2008 at 2:04:21 PM
Revit 2012 stretch arcs |
Thu, Oct 11, 2012 at 1:43:56 PM
Adaptive Component - Flaky Arc |
Tue, Feb 9, 2016 at 1:26:48 PM
Members: | 2016947 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
