50 Users Online (49 Members):
Forums >> Revit Building >> Technical Support >> Display Phase I & Phase II Room Names Together
103 Posts No Rating |
Is there a way to display both Phase I and Phase II Room Names on the Same Plan? When I set the View Properties Phasing to Phase I, only those respective rooms will show up and the same goes for Phase II. I'm trying to show a master plan for coordination purposes. Any suggestions would be appreciated.
Incidentally, I thought I could outsmart Revit by resetting the Phase I Rooms to Phase II. However, rooms can never be changed to a different phase. Looks like I'll have to overlay new rooms on top of old rooms instead unless there is a better solution.
You could always place one view on top of the other on a sheet. One view only has romms and room names.
Yeah that worked out pretty good. I just have to remember to use a blank viewport so the name does not show up on the sheet. It beats creating new Phase II rooms, which would interfere with the room schedule and confuse Revit's room boundaries.
transferring room names form one phase to thenext |
Thu, Sep 12, 2013 at 2:32:14 PM
Problem with Phased plan display |
Wed, Jun 14, 2017 at 10:13:33 AM
Room Numbering & Phases |
Thu, Aug 27, 2015 at 3:01:49 AM
Room names not showing up on different phases |
Wed, Apr 25, 2012 at 10:47:08 AM
Showing a Phase 1Section Tag in a Phase 2Plan |
Wed, Nov 30, 2011 at 12:33:13 PM
Members: | 2030517 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
