Forums >> Revit Building >> Technical Support >> See-through walls? I can't make the walls solid.
Wed, Jan 9, 2013 at 12:49:26 PM | See-through walls? I can't make the walls solid.
tacyb04
For some reason the walls on my second story are see-through. I'm using Revit 2013. I have checked the properties and everything seems to be set the same as the walls on the first floor. Any help is appreciated. I have attached pictures.
Wed, Jan 9, 2013 at 12:55:17 PM | See-through walls? I can't make the walls solid.
4 Stars: 203 Votes
Update your "Graphic card drivers", also try to turned off "Hardware Acceleration" in your "Options"
Printing solid walls
Thu, Jun 8, 2006 at 11:07:17 PM
solid walls transparent to curtain walls and railings in back..
Mon, Oct 29, 2012 at 7:34:26 AM
When you can't make all walls join correct, what you do? [ 1 2 ]
Wed, Oct 7, 2015 at 2:15:30 PM
15
Separating walls
Mon, Jul 3, 2006 at 8:18:21 AM
Make Walls Grey and Transparent in Plan view 'Fine Detail'
Thu, Nov 3, 2011 at 7:30:56 AM
Page generation time: 1.7673
