Forums >> Community >> Newbies >> In-Place Mass Wirefram
61 Posts No Rating |
When i draw a In-PLace Mass i just see them in a wireframe visual style. But everything else in my project is Shaded.
What do i do to make the in-place mass "Shaded" or the same as the rest of the project?
Thanks!
D
Apply "material" to the Mass
Ok thanks.
I can“t figure out how to do that..? (i just started using the program)
Select the MASS, goto properties > Materials and Finishes, now you can select the mat. you want or create a material parameter for tha...
Thanks !
Sweeping Solid In-Place Mass |
Tue, Apr 27, 2010 at 3:30:38 AM
Issue creating mass floor area schedule (mix of families & 'model in place' mass |
Thu, Sep 27, 2012 at 7:05:36 AM
gable mass in place model |
Mon, Jan 16, 2012 at 6:41:13 PM
14
No top surface for in place mass |
Tue, Feb 19, 2013 at 9:55:33 AM
Cutting a section through a mass |
Sat, May 16, 2020 at 4:21:54 AM
Members: | 2118807 | Objects: | 23205 | Forum Posts: | 152310 | Job Listings: | 3 |
