50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> structure model disappear in the detail plan
Tue, Jan 8, 2013 at 10:32:01 AM | structure model disappear in the detail plan
xixiha
This has happened a few times --
After I create a detail plan, the structure column disappeared in that detail plan. But in the parent view, the structure elements is still there. In my memory, it sometims happens, but sometimes not. What's happening?
Tue, Jan 8, 2013 at 10:48:12 AM | structure model disappear in the detail plan
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Is the view set to the correct discipline?
Tue, Jan 8, 2013 at 11:14:04 AM | structure model disappear in the detail plan
xixiha
The discipline is architectural.
Tue, Jan 8, 2013 at 12:10:48 PM | structure model disappear in the detail plan
They will show in a plan view - not a detail view.  I have not figured out why this happens... I just either add a detail component or use a floor plan call-out instead of detail.
Tue, Jan 8, 2013 at 12:20:29 PM | structure model disappear in the detail plan
Manny
3.5 Stars: 6 Votes
make sure that when you create your Callout you use structructural plan rather than detail.  for some reason columns will disappear on detail callouts.
Tue, Jan 8, 2013 at 1:34:59 PM | structure model disappear in the detail plan
xixiha
I actually know this work around too-- using plan callout instead of detail callout. But the reason of it is a mystery to me for a long time.
At least I know today, it's not only me.
Linked file model missing attached detail group
Mon, Aug 17, 2009 at 8:26:39 AM
Embedded Detail Shows in plan view, but not in the plan detail call out!
Fri, Mar 4, 2011 at 1:37:24 PM
plan detail callout in section
Fri, Mar 29, 2013 at 12:48:12 PM
14
SketchUp into Revit Structure 2009
Fri, Feb 27, 2009 at 9:51:25 AM
Detail level - arch vs structure
Tue, Jan 20, 2009 at 9:05:51 AM
Page generation time: 1.4028
