Forums >> Revit Building >> Technical Support >> Trimming sweeps
11 Posts No Rating |
I am doing a building that has a lot of facia and trim that intersects.
How do I get my vertical and horizontal wall sweeps to intersect cleanly? Specifically where angled roof facia boards and vertical wall sweep (tims) intersect. Right now I either have them overlapping (and you see the overlap) or the vertical falling short, creating a trianglaur gap...
interesting, never tried before, you could try the join tool, but I doubt it will work... try to get it as close as you can and if all failed, try a filled region...
How do people draw houses, if you cannot do this? Facia board often intersects verticle trim and vertical and horizontals often intersect?
#1 we don't draw houses or anything else in Revit, we model them.
#2 you would be better off using a corner board trim family that has a top angle to it.
I don't do residential so I don't have one, but do a search in this formum and on AUGI as I have seen this talked about many times in the past.
19 Posts No Rating |
I use the join geometry tool to clean up horizonal and vert. sweeps.
----------------------------------- john a |
wall sweeps not trimming to gable roof |
Fri, Jun 19, 2009 at 7:42:10 AM
11
Trimming Wall Sweeps |
Fri, Jan 19, 2007 at 4:44:15 PM
Trimming Precast-Hollow Core Slabs |
Wed, Jun 3, 2009 at 10:52:22 AM
Problem connecting wall sweeps (horizontal and vertical) |
Fri, May 4, 2012 at 2:07:27 PM
Angling Wall Sweeps |
Mon, Aug 15, 2011 at 1:26:42 PM
Members: | 2115689 | Objects: | 23192 | Forum Posts: | 152301 | Job Listings: | 3 |
