55 Users Online (54 Members):
Forums >> Revit Building >> Technical Support >> Array Arc with an offset from centre
136 Posts No Rating |
Hi all,
I'm having a bit of trouble trying to create a family which is basically a half round window with spokes/mullions that array from a centre. (see attached image)
basically i want the spokes/mullions in both directions to be parametric, I'm happy with working out the math for these but can't for the life of me work out how to get Revit to let me do what I want. Hopefully one of the genius' here can shed some light on it for me ![Winking](/images/smiles/wink.gif)
The outward splaying spokes are a simple radial array, it's the arcs that need to be an array to allow for different numbers from the centre, hopefully this can be done ![Winking](/images/smiles/wink.gif)
Thanks in advance
For Architectural Services visit www.jrpcad.co.uk |
Use ref lines to control the arcs. These can have parameters to control them.
yeah but is there a way of arraying the arcs, so i can add an "arc number" parameter to the family so rather than just having say 3 internal arcs, I may want 5. Obviously each arc will be a different size so a standard array doesn't work. Is there a way to achieve this?
Edited on: Mon, Jan 7, 2013 at 7:48:49 AM
Parametric Array Constraints |
Tue, Jul 2, 2019 at 7:00:45 AM
Vertical Offset, Polar Array |
Tue, Mar 21, 2017 at 3:04:39 PM
how can I array along spline? [ 1 2 ] |
Fri, Nov 28, 2008 at 7:07:32 AM
19
Creating an Array along path |
Thu, Sep 6, 2018 at 10:56:48 AM
Radial/ Polar Array. |
Tue, Feb 5, 2008 at 5:39:48 PM
Members: | 2022314 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
