48 Users Online (46 Members):
Forums >> Revit Building >> Technical Support >> level heights for different buildings
I am doing a project which includes a site of several buildings. I have the main building on the site set to 4 metres per level. However another building on the site has a floor height of 3 metres.
Is there anyway to set different levels for different buildings in the same revit file.
14 Posts No Rating |
You probably should just link the different buildings together rather than have all in the same file.
you should link them into a site file...
each will come with it's own levels and you can hide what you don't want to see.
or, hide all the levels in your linked files and have your levels in the main site file, when you cut sections or elevation hide the levels that do not relate to your building...
am i making sense? it's still early in the morning...
could you explain how to link files. have tried before and had no luck
thanks
Topo Height vs Level Heights |
Fri, May 13, 2005 at 3:25:34 PM
changing multiple level heights |
Wed, Oct 31, 2012 at 9:54:11 AM
Floor level Heights Revised |
Tue, Jan 15, 2013 at 11:58:49 AM
build topo after buildings |
Fri, Mar 3, 2006 at 3:17:19 AM
Multi-level buildings |
Tue, Feb 17, 2009 at 2:27:04 PM
Members: | 2056546 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
