35 Users Online (34 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Walls in design option
Mon, Jan 23, 2006 at 3:31:50 AM | Walls in design option
jyothi
Hi, I have 3 different options to be worked out for a client inn terms of elevation. There is change in roof,which i am able to work.But the problem is there is variation in the type of window,door and only in wall material in front elevation only.To insert window i have created different walls in alll the option at same place is there any other way than this. And second question is how do we take care of schedule,those wall will be accounted twice even if i create different schedule and asign the option. Please help regarding this. Thanks,
Mon, Jan 23, 2006 at 5:22:18 AM | RE: Walls in design option
jyothi
hi, Adding to the above question is there any tutorials that i can go through. I saw similar post by Bhawani, but i counld not browse through the link that was given. Thanks
Mon, Jan 23, 2006 at 5:23:39 AM | RE: Walls in design option
jyothi
hi, Adding to the above question is there any tutorials that i can go through. I saw similar post by Bhawani, but i counld not browse through the link that was given by jobcaptain. Thanks
Mon, Jan 23, 2006 at 10:58:33 PM | RE: Walls in design option
jyothi
hi, I am really sorry guys for posting my thread in the wrong cateogry.i should have posted in technical issue but some how i have posted here i apolozise for having wasted your time. Thanks
Design Option Issue - walls in 1 design option cutting thru a 2nd option
Thu, Oct 21, 2010 at 11:55:04 AM
Cannot place room in Design Option
Wed, Apr 18, 2012 at 4:41:43 PM
Design Option view setting
Fri, May 16, 2014 at 8:02:11 PM
DESIGN OPTION ISSUE?????
Thu, Nov 5, 2009 at 9:54:25 AM
Remove items from a Design Option?
Mon, Jan 3, 2011 at 8:29:57 AM
Page generation time: 1.7808
