47 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Tag Issues - Attached Leader Unwanted Offset
Mon, Dec 31, 2012 at 11:24:35 AM | Tag Issues - Attached Leader Unwanted Offset
braj2421
I'm having a strange issue when tagging elements with an attached leader, the tag, leader, and arrowhead are inexplicably offset from the tagged element.  I've attached an image of this happening with a ceiling tag.  We are a multi-discipline company and this is happening in both the architectural and mechanical models.  The simplest work around is to detach the leader and manually point them to the element, but this is creating a lot of extra work for our mechanical engineer when tagging his air terminals as there are often multiple in one space in close proximity, he is having to double-check every tag to make sure it is pointing to the correct element.
When creating a new project with the same template and using the same tag families this problem does not occur which leads me to believe it is a problem with the project file.
Has anyone had this happen to them before?
Thanks in advance
Revit Architecture & MEP 2012 - Build:20110916_2132 (x64) - Update Release 2
Mon, Dec 31, 2012 at 12:18:16 PM | Tag Issues - Attached Leader Unwanted Offset
I have never seen this and I have not seen anyone else bring up this problem.
Did you check another machine to make sure it is not a graphics card issue?
Mon, Dec 31, 2012 at 12:46:56 PM | Tag Issues - Attached Leader Unwanted Offset
braj2421
It is happening on every machine I've opened the file with. I will continue to look into it and post here if I find out anything, I will most likely end up contacting Autodesk
Thanks for taking a look
Room Tag Leaders
Thu, Oct 21, 2021 at 9:45:57 AM
ceiling annotation tag custom family
Mon, May 14, 2012 at 11:22:46 AM
Positioning the leader on a tag.
Thu, Aug 6, 2015 at 12:16:40 PM
Room Tag w/o leader
Fri, May 6, 2016 at 7:01:52 AM
Leader Line Origin in Ceiling Tag
Tue, Jun 28, 2011 at 7:28:13 AM
Page generation time: 1.6779
