81 Users Online (79 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Workflow & Implementation >> API & Third Party Apps >> Revit 2013 API
Sat, Dec 29, 2012 at 1:03:20 AM | Revit 2013 API
Bretto
Starting to play around with the API and had a small starter project in mind as a learner...Is there access to the dimension properties to access there length and then alter them using the API (with new length parameter)Just thought i would thow it out before i waist time on something that may not be possible?
Mon, Dec 31, 2012 at 10:32:37 AM | Revit 2013 API
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I don't really understand what you are asking?  You want to dimension an object (say distance between 2 walls) then change what the dimension reads?
WorksetExplorer for Revit 2013
Wed, Mar 20, 2013 at 9:48:17 AM
UNWANTED MESSAGE
Tue, Sep 20, 2016 at 9:56:34 AM
Add size_lookup formula via Revit API
Mon, Mar 21, 2016 at 8:53:26 AM
API?
Fri, Apr 27, 2007 at 4:43:36 PM
API For all room elevations in one building model
Wed, Dec 17, 2014 at 1:19:52 AM
Page generation time: 1.8113
