56 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Precast Plank Showing as cut
Fri, Dec 28, 2012 at 10:28:56 AM | Precast Plank Showing as cut
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I have put some precast plank in on a project as a beam system, everything looked fine.  There is an angled wall where I needed one of the planks to be cut to follow the profile of the wall so I created a reference plan on that wall angle and did a simple cut geometry and it cut it just the way I wanted it, however now I can see the cores of the plank that I cut back as though I am cutting through the plan itself.  It happens on all of the planks I cut like this, even if I use uncut geometry and set it back to the original for it still looks as though it is being cut through the cores.  Any ideas how to get this to look like the rest of the planks again?  Everything is at the same elevation so it is not a view range issue
Fri, Dec 28, 2012 at 1:04:14 PM | Precast Plank Showing as cut
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Nevermind, i created a new view and problme was solved. must have just been a little glitch.
New Beam/Plank Family
Thu, Feb 19, 2015 at 8:20:42 AM
Precast Beam System not sitting on beam
Thu, Jan 10, 2013 at 11:45:49 AM
Cut Planes for CMU Bearing Wall Systems
Thu, Jun 4, 2009 at 6:08:29 PM
Custom Precast Family
Fri, Mar 18, 2016 at 2:48:13 PM
WOOD PLANK FLOOR
Mon, Apr 9, 2007 at 5:52:00 PM
Page generation time: 1.5614
