52 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Having trouble with sweeping a sketch
Thu, Dec 27, 2012 at 2:58:30 PM | Having trouble with sweeping a sketch
msavko
Hey all, I'm new to Revit 2013 and am focusing mostly on the MEP side of things but one structural portion I need to get figured
out is how to create UniStrut PS-200, shown in this .pdf here: [url]http://www.powerstrut.com/ps200pdf/ps200.pdf[/url]
I would prefer to make this so that it gets placed just like any other structural item, such as C-Channel. You load the family,
click the first point, drag along the desired length and click again to end it. Below I'll lay out the steps I began to take so
you can see where I am stuck.
1. I did New -> Family -> Generic Model
2. I began drawing the profile shown in the above .pdf, and got it centered along both of the axis that show when you open
the new family.
Now I'm stuck. I started going down this route assuming I needed to make a profile first because when I open the C-Channel
family and go into the editor, it appears it was created with a profile and then a sweep. The sweep function wasable to select
the profile of the channel. I can't seem to figure out how to convert my sketch into the profile, which then can be swept.
Thanks fellas!
Thu, Dec 27, 2012 at 3:18:17 PM | Having trouble with sweeping a sketch
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You need to create that using Generic Model LINE BASED.. go to a right side or left side view, draw your profile and add the Length parameter to the Extrusion End constraints.
Edited on: Thu, Dec 27, 2012 at 3:21:14 PM
Sketch up
Thu, Mar 15, 2007 at 6:46:51 PM
Question about sketch Mode
Thu, Jan 17, 2013 at 6:34:57 PM
Revit into Sketch-up?
Wed, Feb 17, 2010 at 1:08:27 PM
picking points from the 0,0,0 p.
Wed, Jan 21, 2015 at 2:17:21 PM
Creating Sketch Sheets and linking revision tags to Original sheet...
Fri, Jul 14, 2017 at 11:16:32 AM
14
Page generation time: 0.4489
