51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Building Pad for cantilever building
Thu, Dec 20, 2012 at 3:46:09 PM | Building Pad for cantilever building
hydyr96
4.5 Stars: 8 Votes
Hello evryone, I'm using revit architecture 2012, currently I'm designing a cantilever building (a part of which is cantilever actualy) well, I create my building pad, pretty nice, it cuts a portion of site that I don't want in my building, however, it creates an extruded soil under the cantilever part of my building. Any help will be highly appreciated.Previously i've faced with such problem, but I solved it cheating with site points... pretty messy work and honestly works just for renderings... but as we know the final aim a smart model....Here is 3 piv. first: a building before pad was created, second: after creation (you can see soil filled by pad), third: the previous project (where i was cheating Smile )Thanksss....
Thu, Dec 20, 2012 at 3:58:11 PM | Building Pad for cantilever building
Limit your pad sketch to the appropriate contour.
And obviously - the pad is not defines as your floor.  That is actually a floor.
Edited on: Thu, Dec 20, 2012 at 3:59:20 PM
Thu, Dec 20, 2012 at 3:59:48 PM | Building Pad for cantilever building
hydyr96
4.5 Stars: 8 Votes
This is what I've done previous, (see 3rd picture) but, it's to bloody and not precise, yes, for rendering is - ok, but for drawings... doesn't work.. Sad
What you mean... "This is actually a floor?"
Edited on: Thu, Dec 20, 2012 at 4:00:47 PM
Thu, Dec 20, 2012 at 5:19:59 PM | Building Pad for cantilever building
CDWdavid
5 Stars: 5 Votes
Please see attached site plan and section.In section, you can see floor and pad, the pad is only half of the building.The thickness of the pad was 12", with minus 1'-0" Height Offset from the level 1.You can change the pad thickness to 0.125" or even thinner, then you can hide it on section.Then go to the site plan to see the extent of the pad.Hope that is what you want.
That is what WWHub meant.
Thu, Dec 20, 2012 at 6:33:52 PM | Building Pad for cantilever building
hydyr96
4.5 Stars: 8 Votes
Thanks a lot, for both of replies. Although not exactly what I wanted, but still, last one was pretty usefull,- I decided to create a level at the bottom of my floor, - Then I've chenged the viewrange from 1200mm to 0 (So I could see where exactly soil passes from)
- after that, MANUALY i've drawen lines. (Bad part is that we can't pick the lines of site)
And here it is.. promise to share the renders after completion Again thanx... Winking
Building Pad Problem
Thu, Dec 20, 2012 at 3:51:08 PM
Building Pad Altering My Topography Surface
Wed, Nov 30, 2011 at 12:01:59 PM
Building Pad and Ecotect
Wed, Feb 2, 2011 at 11:12:06 AM
building pad
Wed, Dec 2, 2009 at 8:34:09 AM
Building pad, what is it exactly?
Mon, Dec 20, 2010 at 11:51:40 AM
14
Page generation time: 0.8190
