45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> detail lines
Sun, Jan 22, 2006 at 12:04:40 PM | detail lines
cima
Is there a way to modify detail lines (dotted, dashed, etc)?? It seems that linework doesnt work with them. I suppose I'm using detail lines correctly, as what I want is to define is plumbing lines or other furnitures on independent plans.
Sun, Jan 22, 2006 at 5:13:26 PM | RE: detail lines
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
To modify a detail line: Select the detail line, and change its type in the drop down menu. (also the same for model lines) The linework tool only works on edges of solids.
Mon, Jan 23, 2006 at 5:15:08 AM | RE: detail lines
cima
yep, I arrived already there, but the only option it gives to me is between thin, wide, medium lines, when I want to change the style (dotted, dashed....)
Mon, Jan 23, 2006 at 2:10:20 PM | RE: detail lines
arccodex1
3 Stars: 1 Votes
You'll find the loaded line patterns under Settings... Line Patterns. If what you want isn't there you'll have to create a new line pattern. Then you'll find the loaded line styles under Settings... Line Styles. If your desired line pattern is not associated to a line style then create a new line style by clicking on the Modify Subcategories button.
Mon, Jan 23, 2006 at 4:10:30 PM | RE: detail lines
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In families new linestyles can be created in your object styles setting menu.
Can you convert model lines to detail lines?
Wed, Mar 31, 2010 at 12:45:23 PM
Model Lines to Detail Lines???
Sun, Aug 31, 2008 at 9:24:50 PM
call outs and detail lines best practices?
Tue, Dec 15, 2009 at 8:46:41 AM
detail lines WITHIN wall types
Wed, Jul 11, 2007 at 6:26:11 PM
grid lines extend beyond detail
Mon, Jul 20, 2009 at 2:06:00 PM
Page generation time: 1.1172
