49 Users Online (48 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> How Do I Create Existing and Demo Floor Plans From Linked Model
Thu, Dec 20, 2012 at 7:58:52 AM | How Do I Create Existing and Demo Floor Plans From Linked Model
danielfolk20
I linked the Architects model into a new project and we are renovating an existing building so I want the existing floorplan and new floorplan. When I copy/monitored the levels into the project, it only shows the new floorplan. How do I get the existing floorplan showing the existing and demo'd walls? I tried to change the phase but it still doesn't show the demo'd walls.Thanks,
Thu, Dec 20, 2012 at 8:12:37 AM | How Do I Create Existing and Demo Floor Plans From Linked Model
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Under Visablility Graphics go to Revit Links, Display settings, custom and make sure the phase is showing up correctly there, you may need to customize the links display settings.
Thu, Dec 20, 2012 at 8:55:20 AM | How Do I Create Existing and Demo Floor Plans From Linked Model
danielfolk20
Thank you.  That fixed it but brought up a new questions.  For some reason, I can't make changes to the plan that I'm in like the scale of the plan or if I go into the Visibility Graphics box everything is grayed out.  The only way it will let me make changes is I have to click on the button next to View Template and make the changes in the Apply View Template dialog box instead of in the actual plan itself.
Why is everything grayed out in the plan like the scale and visibility graphics without having to edit these in the view template?
Thu, Dec 20, 2012 at 9:04:15 AM | How Do I Create Existing and Demo Floor Plans From Linked Model
In 2013, they changed the way view templates work.  <<< BAD
Now the templates, if assigned to the view, actually lock it and nothing can be controlled that is controlled in the assigned view template.  You are stuck with either taking away the assignment or always modifying the template.
Thu, Dec 20, 2012 at 9:08:58 AM | How Do I Create Existing and Demo Floor Plans From Linked Model
danielfolk20
Wow!  What a pain in the arse!!  I would rather work in Revit MEP 2012 but the arch is using 2013 so I didn't have a choice, and this is my first time using 2013.  I hope they didn't "fix" other things that I'm used to in 2012.
Thu, Dec 20, 2012 at 9:20:07 AM | How Do I Create Existing and Demo Floor Plans From Linked Model
Please add your comments to this thread on AUGI http://forums.augi.com/showthread.php?145104-2013-Default-View-Templates&p=1207306#post1207306
Autodesk pay's more attention there.
Existing Elevations not Referencing Existing Plans
Thu, Dec 5, 2013 at 3:57:30 PM
Floor Demo
Fri, Mar 20, 2009 at 3:24:17 PM
Revit Architecture 2011 - Existing floors show up as black in demo plans
Thu, Oct 27, 2011 at 11:12:41 AM
Existing floor with a new stair opening... need help with phasing
Thu, Apr 25, 2013 at 11:10:35 AM
existing, demo and new roof
Wed, May 28, 2008 at 8:21:31 AM
Page generation time: 1.3251
