48 Users Online (47 Members):
Forums >> Community >> Newbies >> Masses With Surface subdivide using adaptive component - keeping it speedy?
4 Posts No Rating |
I have a large building in concept design stage. Please refer the image for an understanding.
Problem#1 - is keeping the model speedy for everyone working on this. People with lower spec computers cant work on it basically. The mass forming the skin is an inplace mass with a pattern subdivide mapping a family panel onto it.
Problem #2 - the mass needs be able to be adjusted as the design evolves and hence the use of an inplace mass. but I would very much prefer to be able to work the the external mass family environment where you have 3d work planes etc. and keeps it as a seperate file to be loaded into the main model. only problem with working this was is how to adjust the mass and see the model also. i tried linking the model into the mass family but this option is not available....
Hope all this makes sense and thanks very much to anyone that can help me out on this.
4 Posts No Rating |
Further to this, we ended up using sketchup! a great tool we always use for concept, but if we could effectively do concept stage in revit would be a good thing indeed.
Repeat Adaptive Component to a Surface |
Thu, Dec 4, 2014 at 6:22:18 AM
Cut Adaptive Components [ 1 2 ] |
Thu, Jan 17, 2013 at 4:35:38 AM
18
Adaptive component documentation |
Wed, May 11, 2011 at 3:51:41 AM
Void surface on divided surface |
Mon, Mar 10, 2014 at 5:41:07 PM
Show user created dimensions within Adaptive Component in Sheets (2016) |
Fri, Jul 1, 2016 at 1:55:50 PM
Members: | 2017222 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
