64 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> cant edit my model in place component
Sat, Dec 15, 2012 at 1:23:35 PM | cant edit my model in place component
rivettimoney
1 Stars: 1 Votes
Hey all,
I recently got revit 2013 and i was playing around with it and creating a 'model in place' generic model.  I created an extrusion and set the depth and hit the 'check' to complete it...then when i wanted to change the shape of the extrusion, i could not get back in to edit it.  Does anyone know what the problem is?
Mon, Dec 17, 2012 at 7:22:50 PM | cant edit my model in place component
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Click the component and then click 'edit family'. The following responce may depend on the view you are in. You should see the magenta sketch lines.
Fri, Jan 4, 2013 at 8:52:48 AM | cant edit my model in place component
rivettimoney
1 Stars: 1 Votes
Hey,
I try to click the component and then 'edit family'.  It doesnt work.  Also, I am in a view where I can edit the component (i created the component in that view).
I have no trouble when I do this in the office.  This function is just missing when i installed both revit 2012 and 2013 at home.  Could it be a problem with my computer?
Fri, Jan 4, 2013 at 9:03:11 AM | cant edit my model in place component
This is still a process problem - Get to a view where you can select the component. - plan / elevation ?  The view it was created in would also want to be open even if you can't see it yet.  Tiled views will help you here.
BTW - Lines have to be on in VG
Edited on: Fri, Jan 4, 2013 at 9:04:40 AM
Fri, Jan 4, 2013 at 9:08:02 AM | cant edit my model in place component
rivettimoney
1 Stars: 1 Votes
I know how to 'edit family'.  I do it all the time at work and it works fine.  I have tried doing this in plan, elevation, 3d view.  The object is there, I can see it and click on it...but do not have the option to edit it at all
Fri, Jan 4, 2013 at 9:50:39 AM | cant edit my model in place component
Post the properties box of the element when you pick it.
Fri, Jan 4, 2013 at 9:57:33 AM | cant edit my model in place component
rivettimoney
1 Stars: 1 Votes
What do you mean?
Fri, Jan 4, 2013 at 10:01:06 AM | cant edit my model in place component
When you click on the element - the properties box is displayed if you have that open.  Post an image of that.
Fri, Jan 4, 2013 at 10:09:43 AM | cant edit my model in place component
rivettimoney
1 Stars: 1 Votes
I'll have to wait till im at my home computer, I will send it later this evening.  Im wondering if its a problem with my installation or with my home computer although i dont know why.  Because both the 2012 and 2013 programs are missing that function.
Fri, Jan 4, 2013 at 10:35:29 AM | cant edit my model in place component
4 Stars: 202 Votes
Did you installed "Web Updates" too?
Fri, Jan 4, 2013 at 10:41:44 AM | cant edit my model in place component
rivettimoney
1 Stars: 1 Votes
I did not install updates.  Will that make a difference?  how do i do that?
Fri, Jan 4, 2013 at 10:45:50 AM | cant edit my model in place component
4 Stars: 202 Votes
Here: http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9273944
Fri, Jan 4, 2013 at 11:00:36 AM | cant edit my model in place component
#13
rivettimoney
1 Stars: 1 Votes
So, i need to install updates in order to re-edit a generic model?
Fri, Jan 4, 2013 at 11:12:00 AM | cant edit my model in place component
#14
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I would be very surprised if this problem is solved by doing a software update. My gut feeling is we are not being given the whole story.
When you installed the software at home where did the software come from ??
Is it legitimate, non pirated Autodesk  installation ?? If you got the softawre of a torrent site then it's probably crap.
Let us know if the software update worked.
Edited on: Fri, Jan 4, 2013 at 11:12:38 AM
Fri, Jan 4, 2013 at 11:19:30 AM | cant edit my model in place component
#15
rivettimoney
1 Stars: 1 Votes
the 2013 revit was pirated, the 2012 version is the exact same copy i installed on my work computer, which worked fine.  Its strange that in both versions it didnt work.  Will let you know about the updates.
Model in place component
Wed, Oct 11, 2017 at 11:46:06 AM
component orientation
Mon, Jul 2, 2007 at 3:53:42 PM
Profile uploading for model in-place component sweep
Sun, Oct 21, 2012 at 6:28:15 AM
Model-In-Place Component adhering to plan's view range.
Mon, Apr 12, 2010 at 12:18:44 PM
How can I reference lines/circles/geometry in my model from a component?
Thu, Nov 19, 2015 at 12:30:30 PM
Page generation time: 1.4943
