91 Users Online (90 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Same Building on Site Plan with different elevations?
Fri, Dec 14, 2012 at 3:10:11 PM | Same Building on Site Plan with different elevations?
awebre
Point me to the thread if this has been asked before, but I couldn't find it.  I'm linking a large multifamily buildinginto a site model.  The building occurs on the site 3 times, and there are only subtle differences between the 3 linked instances -- I'm handling these with Design Options.  My question is this: Building A, B, & C occur at different siteelevations.  Is it possible to have each linked instance of the building model display at different elevations in thesite model?  How is this done?
I assume people have done this before with multiple house types on a site with differing topo, but I can't figure it out.I'm using Revit 2013.  Thanks.
Fri, Dec 14, 2012 at 3:59:34 PM | Same Building on Site Plan with different elevations?
awebre
Nevermind. Got it. I was able to keep the 0'-0" level in the main building model and then adjust each instance up and down in the site plan.  I then set up levels in the site plan file that corresponded to the F.F. elevations of eachoccurance.  These are per sea level.  So far, so good.
Placing building elevations
Mon, Jan 30, 2012 at 7:32:28 PM
Moving Building up with out moving the site
Sun, Jul 31, 2016 at 5:20:11 PM
Site plan under building
Mon, Feb 1, 2010 at 8:42:08 AM
Site Plan & Moving Building Model
Fri, Mar 9, 2007 at 10:22:56 AM
One site, many buildings
Wed, Feb 11, 2009 at 8:10:46 AM
Page generation time: 1.2387
