168 Users Online (167 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> 2013_reference line in project environment
Fri, Dec 14, 2012 at 9:34:51 AM | 2013_reference line in project environment
KHAJG
I'm trying to set up some overall geometry for curtain wall in the project environment. I need to use arcs for some of the geometry and was looking for the reference line button, but it seems only reference plane is available? How can I create non-printing/sketch lines that are not linear in the project environment?
Fri, Dec 14, 2012 at 10:16:47 AM | 2013_reference line in project environment
Either use reference planes or create a view that is not on a sheet and use detail lines.
Fri, Dec 14, 2012 at 10:59:33 AM | 2013_reference line in project environment
KHAJG
Thanks, might have to create separate view... Unless I'm missing something really obvious, reference planes can't be curved right? It just seems strange that reference lines is not an option in the project environment..
Fri, Dec 14, 2012 at 11:32:38 AM | 2013_reference line in project environment
Reference lines are useful in the family editor because they are used to control model elements.
Why do you need a reference line in the project?  .... You don't need a reference line to darw a line - just draw it!  You don't need a reference line to place a model element - place it and use Revit's automatic functions.
Fri, Dec 14, 2012 at 11:55:37 AM | 2013_reference line in project environment
KHAJG
I guess I'm not controlling anything with these lines. Basically, these are construction lines to determine the geometry of the curtainwall. I just want to be able to draw lines (and curves) that are understood to be construction lines and that will not be printed in any views later if I forget to delete them...
Fri, Dec 14, 2012 at 12:40:59 PM | 2013_reference line in project environment
It is far easier to just draw the curtain wall ... then modify it if required.  That's what is great about Revit.
Sharing Coordinates Conceptual Mass Environment and Project Environment
Sat, Nov 16, 2013 at 10:14:01 AM
building environment
Mon, Aug 3, 2015 at 1:30:13 AM
Revit and IES Virtual Environment
Fri, Feb 13, 2009 at 6:25:02 PM
14
Cant make editable labels in a title block.
Fri, Aug 7, 2020 at 1:11:02 AM
Deleting an element within 3D environment doesn't delete the element from the 2D
Tue, Jun 26, 2012 at 12:46:08 PM
Page generation time: 0.9829
