32 Users Online (30 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Walls are greyed out
Fri, Dec 14, 2012 at 5:23:42 AM | Walls are greyed out
timOthyj
4.5 Stars: 14 Votes
hello I have multiple levels in my rev.2013 drawing using the construction template. When I draw a wall on the first floor they are fine, when I switch to the 2nd floor plan i cannot see the walls below and I have the underlay set to the level below..plus in 3d view the walls on the 2nd floor that I have just drawn are greyed out. Same with the level below the 1st floor.. What is up..
Fri, Dec 14, 2012 at 5:52:57 AM | Walls are greyed out
4 Stars: 202 Votes
Are you working with: Phases, Coordination, worksets????
Fri, Dec 14, 2012 at 6:54:38 AM | Walls are greyed out
timOthyj
4.5 Stars: 14 Votes
I thought it was all new construction phase..I can send you the revit file...Oh yes I figured out the corner windows, and why my beams werent joining correctly..Smile ty for your help.
Hmmm can I email you the project file and have you take a look?
Fri, Dec 14, 2012 at 6:55:18 AM | Walls are greyed out
timOthyj
4.5 Stars: 14 Votes
How do I know if Im working with coordination worksets?
Walls greyed out in PLAN VIEWS
Fri, Feb 19, 2016 at 4:32:58 PM
walls greyed out
Mon, Jul 6, 2015 at 1:28:48 PM
Half Revit model greyed out in 3d mode
Wed, Jan 30, 2013 at 2:20:46 PM
plotting greyed out title blocks??
Fri, Jun 9, 2006 at 8:46:11 AM
Render options greyed out
Wed, Jul 3, 2019 at 11:17:24 AM
Page generation time: 2.9441
