111 Users Online (110 Members):
Forums >> Revit Building >> Technical Support >> Working with Linked Model
1 Posts No Rating |
Im working with a linked model for the first time creating concrete lift drawings and also just getting back into Revit after 2 years.
Im running into a few issues. Is there anyway to edit the model itself to add more information for schedules and such? If not is it possible to copy monitor or something similar and then add the information?
"Is there anyway to edit the model itself to add more information for schedules and such?" --yes here in revitcity, theres always a way lol. you can edit the link file and update the link on the main file? or bind the link and re-link? or open two revit session to do the updates and so on..
** dont be mad, i dont have much... i am homeless |
If the linked file is a consultants and will change, then you really don't want to edit it.
If these are elements you can copy monitor, then that is a better process.
Edited on: Fri, Dec 14, 2012 at 10:14:46 AM
Not able to place room copied from linked model |
Wed, Mar 18, 2015 at 8:10:37 AM
Linked Revit Model Sheets |
Fri, Apr 5, 2013 at 12:04:28 PM
Linked Model - Losing only some doors from linked model |
Thu, Oct 21, 2010 at 1:52:14 PM
Moving a linked Revit model |
Thu, Nov 21, 2013 at 3:57:59 PM
Linked model view setting not working |
Thu, Jan 10, 2013 at 1:17:23 PM
Members: | 2030633 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
