154 Users Online (150 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Workflow & Implementation >> Hardware >> Dual Xeons e5 vs i7 3770K
Thu, Dec 13, 2012 at 1:46:35 AM | Dual Xeons e5 vs i7 3770K on a Revit Server
klipnov
Would revit server benefit from using the dual xeons? or an i7 3770k would be good enough for revit server to run. For around 30 users. Is it overkill for revit server to run on dual xeons? I have read that people have setup revit servers using average hardware.
I know that hard disk speeds and network bandwith is important but, what about processors?
Edited on: Thu, Dec 13, 2012 at 6:11:43 AM
Edited on: Thu, Dec 13, 2012 at 6:11:59 AM
Thu, Dec 13, 2012 at 1:16:35 PM | Dual Xeons e5 vs i7 3770K
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
You might get a lot of "it depends" answers here.  Personally I refuse to use anything but Xeons in my systems except for laptops, since they aren't available unless you get a brick from BOXX.  The problem I have with most i7's is that yeah, they are crazy fast (like the model you mention) but their bottlenecks are still the very basic things like cache size (puny 8Mb!), they don't support ECC (last time I checked) and the DMI is only 5 Gb/s vs. up to 8 Gb/s for a comparable E5 Xeon.
  If I remember my history correctly, Intel specifically made the Xeon's for servers.  i7's are for gamers in my opinion...however it will be devastatingly cheaper to go with an i7...which only brings trouble when you go cheap!
dual xeons is most likely overkill.
Even this single 6core xeon E5 chip might be overkill:
http://ark.intel.com/products/64589/Intel-Xeon-Processor-E5-2667-15M-Cache-2_90-GHz-8_00-GTs-Intel-QPI
That would get you through the next 2 - 3 years in my opinion.
Bandwidth is the biggest concern most people have when you have 20+ users, not processor speed (although it is important along with a tank full of 1600Mhz RAM.)
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Thu, Dec 13, 2012 at 6:22:55 PM | Dual Xeons e5 vs i7 3770K
klipnov
Thanks rbcameron2,
Just to clear things up. I have never used revit server, but from what I understand. Revit Server just manages the online collaboration(sync/update files) and no rendering takes place. Correct me if I'm wrong.
Just asking around to make sure that Company X makes the right decision before spending a ton of money on something that's not being utilized.
Fri, Dec 14, 2012 at 11:24:25 AM | Dual Xeons e5 vs i7 3770K
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
My Xeon E5-1620 3.6 performs at almost the EXACT same levels as the i7 3770K and is the same price. I find xeons to be much more reliable as well.
http://www.cpubenchmark.net/high_end_cpus.html
Fri, Dec 14, 2012 at 2:28:37 PM | klipnov
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Quoting klipnov from 2012-12-13 18:22:55
Thanks rbcameron2,
You COULD use it render on, but no, RS "basically" is just a place that exchanges models.  This is not the type of server you want to necessarily "cheap out" on since it is where you make or break your time saving files.
The E5-1620 is a good chip too.  I would recommend whatever Xeon E5 series that is around 3.0Ghz - whether its quad, hex or octo-core.  I'm thinking in the neighborhood of $3650 (+/-) for the server you would be looking at.  That includes the cost of an operating system.
Also, any more questions may be directed here.  Believe me, you'll have plenty of WTF questions once RS gets implemented! ha!  Locked model??? What does that mean?
http://www.revitforum.org/worksharing-revit-server/
Edited on: Fri, Dec 14, 2012 at 4:03:03 PM
RB Cameron
Sat, Jun 29, 2013 at 1:04:35 PM | Dual Xeons e5 vs i7 3770K
Astroboy13
Astroboy13 Avatar
The Xeons will do you better. Think what happens if all 30 users go do heavy load stuff an once. The i7 WILL make everyone want to pull their hair out.
Onwards and Upward!
AMD DUAL CORE V INTEL DUAL CORE PROCESSORS [ 1 2 ]
Wed, Jan 25, 2006 at 2:00:11 AM
15
Monitors, dual vs large
Tue, Aug 25, 2009 at 7:27:44 AM
Dual Monitor
Fri, Dec 2, 2005 at 3:29:02 PM
Dual Channel DDR2 RAM
Wed, May 27, 2009 at 7:09:39 AM
Consultant Coordination
Mon, Apr 14, 2008 at 2:35:03 PM
Page generation time: 0.2194
