96 Users Online (95 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Tips & Tricks >> Help ...Joining curtain wall corners!!!
Wed, Dec 12, 2012 at 6:09:58 AM | Help ...Joining curtain wall corners!!!
timOthyj
4.5 Stars: 14 Votes
Hey I need to have a curtain wall join at a corner..How is it done?
I dont want a corner column or anything.
Thanks!
Wed, Dec 12, 2012 at 9:27:26 AM | Help ...Joining curtain wall corners!!!
4 Stars: 202 Votes
You have to "disalow join" those CW then you can stretch the endpoints, Check your help for that.
Wed, Dec 12, 2012 at 10:10:59 AM | Help ...Joining curtain wall corners!!!
Ty - The problem is the top, bottom and horizontal mullions will not be correct if the CW does not extend correctly.
I believe the last time I did this, I added a CW, vertical grid just off the corner at the joining CW glass face.  Then I did not use a vertical mullion on this grid or the end grid and I used empty panels in the sliver that was created.
Wed, Dec 12, 2012 at 1:57:42 PM | Help ...Joining curtain wall corners!!!
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
I would recommend WW's approach.
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Wed, Dec 12, 2012 at 2:55:22 PM | Help ...Joining curtain wall corners!!!
timOthyj
4.5 Stars: 14 Votes
WW..I kinda understand your approach ..I will send the rvt file..Its v.13
Wed, Dec 12, 2012 at 2:57:50 PM | Help ...Joining curtain wall corners!!!
timOthyj
4.5 Stars: 14 Votes
My extension didnt show up..
Wed, Dec 12, 2012 at 3:27:26 PM | Help ...Joining curtain wall corners!!!
timOthyj
4.5 Stars: 14 Votes
@WW.. So if you created empty panels. a).Did you go ahead and create horiz. mullions? B). the empty panels that were created what did you fill them with? And did you actually have a corner?
Thanks for your help.
Wed, Dec 12, 2012 at 3:48:18 PM | Help ...Joining curtain wall corners!!!
Your view requires all the horizontal mullions - just not the vertical corner (and my added vertical).
Wed, Dec 12, 2012 at 5:05:06 PM | Help ...Joining curtain wall corners!!!
timOthyj
4.5 Stars: 14 Votes
I found a way through internet searching..
I just changed the system panel to a custom glass wall the same thickness as the mullions..And it seems to work.
Curtain wall corners
Sat, Apr 5, 2008 at 12:45:05 AM
continuous curtain wall with joints
Tue, Dec 4, 2007 at 9:01:06 AM
Curtain wall and mullion issues
Wed, Sep 5, 2007 at 7:38:15 PM
wall corners not joining clean
Wed, Dec 23, 2015 at 9:25:52 AM
How to connect a curtain wall corner with an angle?
Tue, Oct 29, 2013 at 12:18:48 PM
Page generation time: 1.9024
