35 Users Online (34 Members):
Forums >> Revit Building >> Technical Support >> Revit Arch 2013 - Elevators W/ Entries On Opposite Sides?
23 Posts No Rating |
Hey gang,
I have an elevator that has a front entry at the 1st floor and rear entry at the 2nd floor but I can't seem to find a family that works this way. Can you guys help me out on this one? How do you handle this issue?
Added info:
This elevator will be glass and in a glass enclosure and my PM wants to see it, and be able to see out of it, in the 3D shots. :-/
I doubt that you will find such a family so you will have modify/build your own.
![teafoe5 Avatar](user_avatar/204239.jpg)
![4 Stars: 47 Votes](/images/stars_4.gif) |
I haven't tried this all-in-one family but it looks like its capable of doing what you want.
http://www.revit-content.com/content/elevator/index.htm
It's not free so depending on how often you do elevators and how detailed it needs to be WWHub is probably correct that it may be easiest to create your own.
Yea, I saw that one already. That's not an option. :-P
209 Posts No Rating |
Check ThyssenKrupp they have elevators with the double door cab and a separate family for the doors for the walls.
Edited on: Wed, Dec 12, 2012 at 5:52:59 PM
Huge thanks quinn, that's the kind of help I knew I'd find when I came here. ![Shadey](/images/smiles/shadey.gif)
Any way to assign different colors to opposite sides of doors? |
Mon, Apr 27, 2009 at 10:00:28 AM
Need Help with Revit Arch. 2013 |
Wed, May 22, 2013 at 10:17:50 AM
revit arch 2013 my 3d views are transparent???.. |
Mon, Mar 25, 2013 at 7:45:25 PM
HELP! Revit 2016 Invisible walls and Elevators! |
Tue, Dec 8, 2015 at 4:11:51 PM
Charts - Revit Arch. 2013 |
Mon, Sep 30, 2013 at 8:54:47 AM
Members: | 2022340 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
