Forums >> Revit Building >> Technical Support >> Templates
hi all. using Revit 2013, i know there has to be a way to do this, i just haven't found it as of yet. if you make a wall type in a project, and want to add it to your company template, how can you transfer it? along the same lines, in some of the out of the box templates there are a lot more wall types than in others. for example the Mechanical Template has almost none. how can i transfer wall types from the Architectural Template to the Mechanical Template, or the one that i created for the company? i've already tried to make a 10' wall section with each wall type and then link the project. i copied/monitored the walls, and checked to copy the new wall type. but that still didn't allow me to use those wall types.
Try to learn at least one new thing every day |
We maintain a library project of wall types. These types are shown on a wall types sheet inthe library project. Then to load into a curent project, we simply copy / paste the wall type legend and notes into our project onto it's wall type sheet view.
are you refering to your details? if not would you please give me more detail. i don't need to be able to show details, i just want it to take up the right amount of space, and look right. i'm working for a MEP firm. i have to make the buildings from OLD pdf's from 40 years ago, most of the time. then put in our stuff. i just don't want to have to make the wall from scratch every time i start. building a library as i go would be great, that's what i'm trying to do.
I think I was perfectly clear. Copy/pasting the wall types legend also imports the wall types.
I understood the copy/paste part. i'm sorry that i don't know how to do a legend of 3d wall types. or any other 3d parts for that matter. i've had to use 2d drawings for the legend. i would like to know how to do a legend that had the components that i've used in the project.
New Legend > Component > Legend Component
This tool lets you create a legend from the 3-d objects you have in your projects. Very cool and handy. For other objects besides walls it is important to make sure their symbols look the way you want in a legend though.
But that should answer your question.
High quality modern Revit furniture!
www.therevitcollection.com
The Revit Collection: High Quality Revit Families | Revit Furniture |
Your own HELP explains the process:
Creating a Legend
- Click View tabCreate panelLegends drop-down (Legend).
- In the New Legend View dialog, enter a name for the legend view and select the view scale.
- Click OK.
The legend view opens and is added to the Project Browser list.
- Add the desired element symbols to the view using any of the following methods:
Obviously - everywall type has to have its own unique name - So placing them in a library project allows you to do this in a manner where you can easily pick the correct one.
thank you both for the advice. i'm sorry if it was too remedial of a topic. but i appreciate the answer non-the-less.
Where have my templates gone in 2012 |
Sat, Apr 7, 2012 at 9:09:06 AM
Family Templates |
Tue, Nov 26, 2013 at 9:56:21 AM
Drawing templates |
Thu, Jun 10, 2004 at 1:41:36 PM
lineweight templates for optimal appearance |
Tue, Jul 7, 2015 at 1:58:11 PM
Used based Revit templates |
Fri, May 2, 2014 at 5:17:38 AM
Members: | 2030595 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
