Forums >> Revit Building >> Technical Support >> version 2013_Error message when uploading family
16 Posts No Rating |
Hi, I'm trying to pin-point where the error might be in my family. All I'm getting is the information in the screenshot attached. If I check these errors and click "delete checked..." it works, but I'm uneasy about just just deleting it and would like to figure out what went wrong when I created my family...
Not sure without seeing your family, attach it if possible
Attached is my family..
When you change your family to type 2 it does not work with the parameters you have set. You will need to flex the family and find out what is making that problem. If you delete the Family type 2 and leave 2B it will load into a project and work just fine.
Somewhere in your project, this panel does not work. Use the search by ID number to see where they don't work. You may have to change those panels to something else there.
Thanks everyone! It turns out that one of my extrusions on panel 2 was set to 0", hence the error. Somewhere along the many iterations of this family, I had created a panel 2 and forgotten about it, so while I flexed 2B and it was working, I never thought to flex 2 as well...it's good reminder to check and make sure all portions of the family are working before loading into the project.
How to fixed error when uploading family to project rvt. file |
Tue, Jun 19, 2012 at 4:16:05 PM
uploading new families to older versions |
Mon, Apr 24, 2006 at 11:37:34 AM
Uploading components |
Wed, Dec 10, 2008 at 10:53:39 AM
Uploading a large number of families to newer versions |
Mon, Feb 19, 2024 at 5:11:39 PM
uploading template files no help from revitcity admin |
Sat, Mar 16, 2013 at 7:49:58 AM
Members: | 2115712 | Objects: | 23193 | Forum Posts: | 152301 | Job Listings: | 3 |
