86 Users Online (84 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Systems >> Technical Support >> material in renderings
Thu, Dec 6, 2012 at 3:04:08 PM | material in renderings
mccluren
I just recently built a louver system using the extrusion technique and set a material in the parameters. Once i brought it into my project and inserted the louver system into my building, the material i chose does not show up in the renderings. Even when I change the material to something different, it simply shows up grey in the renderings. Is there any way to make the material of the louver system I created show up in renderings?
Thu, Dec 6, 2012 at 3:08:47 PM | material in renderings
In the family - you have to assign the material to the objects.
Once loaded - THE PROJECT RULES.... see other posts about changing materials.
Thu, Dec 6, 2012 at 10:42:17 PM | material in renderings
mccluren
I have changed the material in edit type, i have changed it in the family, and no matter where I change it or what I
change it to, it just does not show up in the renderings.  I restarted the louver system and made sure to assign a
material early in the process and this did not help either. Any other suggestions?
Fri, Dec 7, 2012 at 3:25:56 AM | material in renderings
4 Stars: 202 Votes
In your PROJECT goto MATERIALS and change there....
Fri, Dec 7, 2012 at 5:43:10 PM | material in renderings
mccluren
I have changed it in my project multiple times and used multiple different materials and it still ceases to show up in renderings.  The program says that the material is wood, but when I render the project, it shows up as grey.
Sat, Dec 8, 2012 at 8:52:45 AM | material in renderings
Please do this exactly....
  1. Open the family in the family editor.
  2. Click on an solid in the family.
  3. In the properties of that extrusion, look at the material.
  4. Post an image of the properties so we can see it.
Wed, Dec 12, 2012 at 2:14:23 PM | material in renderings
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
If you make your materials instance parameters, then you can address them on the fly in the project.  The project will over-rule what the family has.
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Why won't my material show up in my renderings sometimes?
Tue, Feb 13, 2007 at 12:12:20 PM
Roof textures messed up in renderings
Fri, May 16, 2014 at 9:17:15 AM
Best approach to Photo Realistic Renderings? [ 1 2 ]
Thu, Dec 13, 2012 at 3:40:14 PM
15
Poor color rendition in renderings.
Fri, Nov 19, 2010 at 10:50:28 AM
Object Material Not Showing
Wed, Dec 9, 2015 at 9:05:16 AM
Page generation time: 0.6089
