65 Users Online (64 Members):
Forums >> Revit Building >> Technical Support >> Ceiling tags: how can i make them visible in floor plan views
50 Posts No Rating |
I am using the 'out of the box' ceiling tag with height in my ceiling plan, but would like to be able to read the tag in my floor plan. Any ideas?
Thanks
You might be able to do place a very small plan region along a side wall and set the view range so that it includes the edge of ceiling - then tag that.
Edited on: Thu, Dec 6, 2012 at 3:07:18 PM
yes, that does work, but that means little plan regions in all the rooms and thier constant adjustment with height and graphics. ick.
Your only other choice is to add this data manually to your room properties and include that in a room tag. The property has to be a shared parameter.
Symbol lines in both ceiling and floor plans |
Fri, Nov 6, 2009 at 1:01:55 PM
Model not visible in Ceiling Plan views |
Wed, Jul 10, 2013 at 12:56:49 PM
room tags in ceiling plan? |
Wed, Jun 14, 2006 at 4:30:44 PM
To use or not to use . . Floor plan or Ceiling plan . . . for Mech and Lighting |
Tue, Sep 13, 2011 at 11:12:09 AM
How to make a floor plan level into a ceiling level plan in Revit MEP |
Tue, Apr 12, 2011 at 7:09:06 AM
Members: | 2016897 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
