36 Users Online (34 Members):
Forums >> Revit Structure >> Technical Support >> furniture shows up white in floor plan but shows in material in elevation/3dview
5 Posts No Rating |
Using Revit 2013:
I imported some revit furniture models from Steelcase + Herman Miller. I assigned new materials to it that I had imported into Revit by going into model's properties.
A few furniture pieces would show up white in the floor plan but show up correctly in the designated new material in the elevations + perspective views.
I made sure to check the box visibility for floor plan for the models as well. floor plan is also in the realistic view.
What did work was: edit the family > select the entire model> delete the extra mass> add a new parameter (new material; although it came with preset material parameters)> load family> uncheck opacity. The problem with this is that the entire model is in 1 material (instead of 2: seat and frame).
Any other ideas? Is there a way I can override the materials before I load into Revit initially?
Attach the family to take a closer look
topography in elevation shows up "blank" space. any work around? |
Wed, Apr 29, 2009 at 3:20:42 AM
12
Furniture and overlays |
Tue, Sep 24, 2013 at 8:48:23 PM
Material shows up black in elevation with model display set as realistic view. |
Thu, Sep 1, 2016 at 9:50:56 AM
Underlay shows too much! |
Wed, Mar 13, 2013 at 3:57:06 PM
When I cut a section or elevation in revit, it shows what's behind the cut plane |
Fri, Dec 6, 2013 at 12:47:17 PM
Members: | 2026045 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
