Forums >> Revit Building >> Technical Support >> Walls, Split regions and Materials
G'day Reviteers,
I've dealt with this before but for the life of me I can not remember how or if it is possible to make a wall with different materials, top and bottom. Say for instance, Brick on top, stone at bottom. I have a wall with a split region but I can't seem to get that split region to act seperate from the original region. So when I change the dimesion of the lower region it changes the dimension of the entire "Finish 1[4]" layer instead of just the lower region. What am I doing wrong?
Thanks for your time and help!
--Carl
I am still pretty new myself here but I believe the tutorial "Working with Vertically Compound Walls" covers what you are describing. I had to referance this earlier today myself. Good luck I hope this helps.
Post edited on 2006-01-20 13:54:04
The tutorial helped in making different materials. I'm still having problems, however, making the stone layer a different thickness than the brick layer.
Thanks again.
--Carl
Vertically compound walls can only have a single thickness to a layer. They were they only way to split wall finishes in the earlier versions of Revit up until 7.0.
Now Revit has the stacked wall feature which lets you make a compound wall out of individual wall types. I make extensive use of stacked walls. There are some problems with wall joins at times, but nothing I haven't been able to overcome. Check out the help file on Stacked Walls for more info.
Tom
Scheduling cut and fill when using split regions |
Sun, Sep 21, 2008 at 8:56:58 AM
split face not remembering material - RAC 2008 |
Thu, Nov 20, 2008 at 3:13:31 PM
Splitting wall Regions |
Tue, Jan 27, 2009 at 10:16:18 AM
Using Split Face |
Fri, Jul 12, 2013 at 11:00:40 AM
using split face tool on curved walls |
Sat, Oct 12, 2019 at 8:21:20 AM
Members: | 2104596 | Objects: | 23178 | Forum Posts: | 152300 | Job Listings: | 3 |
