104 Users Online (103 Members):
Forums >> Revit Systems >> Technical Support >> unconstrain modeled component from it's work pane?
67 Posts No Rating |
I created a simple revolve using a wall for the inital work plane. I cannot for the life of me find how to unconstrain it from that wall after it is created. I would like to be able to place it anywhere, not just on a plane. I created it under the lighting category.
I searched for this but got internal server error when searching these forums so if somebody can ether give a solution or point me to one that would be great!
I am in Revit 2013
If anyone wants to know, I figured it out. if an element is ever constrained to a work plane just copy paste it and it may lose its constraints :-)
You will find that using a family created in place at multiple locations is a bad process. Model in place is meant to be used at one-of-a-kind uses. If you need multiples, then you should create a family.
modeled component in place...can't move vert |
Thu, Jan 7, 2010 at 7:11:33 AM
Detail Component in Profile Family - Doesn't Work = Why? |
Tue, Dec 22, 2015 at 1:45:50 PM
Component Modeled in place not cutting with section cut. |
Fri, Jun 3, 2011 at 5:43:13 AM
How can you place a component's width by picking two points? |
Thu, Dec 22, 2005 at 3:42:01 AM
NEW WINDOW FAMILY |
Tue, Sep 13, 2005 at 6:03:19 PM
Members: | 2030694 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
