56 Users Online (55 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> ERROR IN STRUCTURE EXTENSION
Tue, Dec 4, 2012 at 3:44:40 AM | ERROR IN STRUCTURE EXTENSION
kulfi
WE ARE USING BY MISTAKE ARCH TEMPLATE AND GEETING THE MESSAGE BELOW
CAN ANY ONE TELL ME WHAT IS THIS PROBLEM AND HOW WE CAN SOLVE IT.
THANKS
Error create REXRevitAccess (REX Parameters)!: Object reference not set to an instance of an object.; StackTrace:    at REX.Common.Revit.Storage.R ...
- Create method exception.
Assembly name: DReinfColumn: Object reference not set to an instance of an object.; StackTrace:    at REX.ContentGenerat ...
REX:
Engine version: 2013; Version name: ; Culture info: en-US
PLATFORM:
Win32NT Microsoft Windows NT 6.1.7601 Service Pack 1
SOURCE:
AREX
MESSAGE: (12/4/2012 12:37:44 PM)
Assembly name: DReinfColumn: Object reference not set to an instance of an object.; StackTrace:    at REX.ContentGenerator.Converters.RVTRebarFactoryCommon.LoadElementsFromProjectInfo()
   at REX.ContentGenerator.Converters.RVTRebarFactoryCommon.InitList()
   at REX.ContentGenerator.Converters.RVTFamilyConverter.InitGlobal()
   at REX.Common.Revit.Concrete.REXRebar..ctor(REXExtension Extension)
   at REX.Common.Revit.Concrete.REXRebarCG..ctor(REXExtension Extension)
   at REX.Common.Revit.Concrete.REXRebarMngr..ctor(REXExtension Extension)
   at REX.DReinfColumn.ReinfFactoryRevit..ctor(REXExtension Extension)
   at REX.DReinfColumn.Extension.OnCreate()
   at REX.Common.REXExtension.Create()
   at REX.DReinfColumn.Extension.Create()
   at REX.Common.REXApplication.Create(REXContext& AppContext)
DEPENDENCY: Autodesk.REX.Framework, Version=2013.0.0.0, Culture=neutral, PublicKeyToken=51e16e3b26b42eda (file version: 2013.0.0.2251) | REX.Controls, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251) | REX.Controls.WPF, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251) | REX.Controls.Forms, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251) | REX.Mathematics, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251) | REX.Preferences, Version=2013.0.0.2251, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251) | REX.System, Version=2013.0.0.2251, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251) | REX.Service, Version=2013.0.0.2251, Culture=neutral, PublicKeyToken=null (file version: 2013.0.0.2251)
LAST ENTRIES: 4 / 45
44: (12/4/2012 12:37:43 PM)
AREX.REX.Foundation - Error create REXRevitAccess (REX Parameters)!: Object reference not set to an instance of an object.; StackTrace:    at REX.Common.Revit.Storage.REXSchemaClass.Load(Element element, Nullable`1 schemaID)
   at REX.Common.Revit.Storage.REXSchemaClass.Load(Element element)
   at REX.Common.Revit.Storage.REXStorageGeneral.LoadRegionalSettings(IREXPreferences2 preferences)
   at REX.Common.Revit.Storage.REXStorage.Setup(REXExtension extension)
   at REX.Common.REXRevitContextAccess.Create()
   at REX.Common.REXRevitAccess.Create()
43: (12/4/2012 12:08:59 PM)
AREX.REX.Foundation - Create method exception.
Assembly name: DReinfBeam: Object reference not set to an instance of an object.; StackTrace:    at REX.ContentGenerator.Converters.RVTRebarFactoryCommon.LoadElementsFromProjectInfo()
   at REX.DReinfBeam.ReinfFactoryRevit..ctor(REXExtension Extension)
   at REX.DReinfBeam.Extension.OnCreate()
   at REX.DReinfBeam.Extension.Create()
42: (12/4/2012 12:08:58 PM)
41: (12/4/2012 12:00:54 PM)
Extension for structure
Sat, May 23, 2009 at 5:17:53 AM
Looking for Revit Structure Extension Text Generator
Mon, Jan 24, 2011 at 2:11:22 PM
Revit Extension Distance at top of Wall - Error
Thu, Jun 11, 2015 at 1:35:29 PM
2016 Revit Lt Timber Extension?
Thu, Sep 24, 2015 at 8:37:07 PM
Civil Structure Extension
Sat, Mar 21, 2015 at 6:35:31 PM
Page generation time: 0.5928
