50 Users Online (49 Members):
Forums >> Community >> Newbies >> Placed Sections on Sheet, Plan Cut Lines Disappeared, But the Sections Remain
I've created section cuts in my model and dragged them onto a sheet. Returning to my model, I discovered the section cut lines have vanished. Going back to the section sheet I see that the missing cut lines have disappeared from every section I cut. I still have all my sections, but can't see the cut lines for them.
Post some images please.
What did you drag onto your sheet? Not the cut but the view? This is not CAD - Sheets are not placed in model views.
Here are some images. One is my section sheet with all the cuts. The other is my model plan showing only two section cutss.
I dragged the section views from the Project Browser.
Sorry about the quality of the image. Not sure what happened there, but you can see that I have only two sections on the plan but many more on the sheet.
If this helps, when I select a section in the Project Browser and right click to select 'Find Referring View' I get the following error message: 'Could Not Find Referring Object'.
Okay. After much web surfing, I finally firgured it out. I opened one of my missing sections and then had to go to the Properties 'browser' on the left side of the screen and under the GRAPHICS heading I found the HIDE AT SCALES COARSER THAN. I changed the setting to the lowest, 1:400. That made the section tag appear on my plan. I then had to do that for all my missing section tags.
Thanks for everyone's help.
Sections are disappearing! (Revit 09) |
Mon, Dec 8, 2008 at 10:04:50 AM
Wall sections cut from elevation... now not seen on plan |
Fri, Mar 9, 2012 at 11:05:12 AM
building sections visible but detail view sections NOT visible on all drawings?? |
Tue, May 27, 2008 at 12:50:20 PM
Familys in Sections |
Fri, Jan 26, 2007 at 10:12:00 AM
Numbering Sections |
Wed, Jul 15, 2015 at 1:49:32 PM
Members: | 2022340 | Objects: | 22974 | Forum Posts: | 152200 | Job Listings: | 3 |
