43 Users Online (41 Members):
Forums >> Revit Building >> Technical Support >> Section head shared parameter
![Lochnesska Avatar](user_avatar/262107.jpg)
Hello. My firm has strict library rules and layers code. They all use AutoCAD but I'm quite stubborn and I still think that Revit is so much better for architecture. However, I can use it so it's cool.
I've spent a lot of time searching any clue how to do this:
In section head, I don't want to know on which sheet this view is referenced, or any other of the 6 possible label parameters.
I want just a new shared parameter that I could tell the section that its number is 001 and the type (section or elevation). Unfortunatelly the possibility to pick a shared parameter in label is greyed out so I can't do this.
Any clue?
Using Revit 2013
Nessie
Revit 2013 |
In fact I realised that there is no information in the section head as long as you put the section on a sheet... I don't need this, I have to export to dwg for the presentation....
Nessie
Revit 2013 |
If want something dumb for CAD, then don't use a section head, make a symbol.
This user is online |
Could this symbol be attached to the section? That I don't have to do everything manually?
Nessie
Revit 2013 |
Can not be attached to a section cut. Remember - this is dumb.
Hide Section Head in Shared File |
Mon, Aug 30, 2010 at 7:14:49 AM
Shared Parameter's will not show in Schedules |
Wed, Oct 9, 2013 at 8:36:07 AM
Trying to Import Filled Section Head |
Mon, Jun 27, 2016 at 2:32:45 PM
Referencing a Shared Parameter in a Family parameter formula. |
Thu, Jan 29, 2015 at 1:26:24 PM
problem with section head |
Sun, Nov 26, 2006 at 4:49:05 PM
Members: | 2019206 | Objects: | 22958 | Forum Posts: | 152184 | Job Listings: | 3 |
