67 Users Online (65 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit Closes every time it loads
Thu, Nov 29, 2012 at 10:02:48 PM | Revit Closes every time it loads
10samcarl
I have been running Revit 2013 on my pc with no problems for awhile. I have not made any major changes to my system,
but now every time i open revit, it loads all the way into the main menu where you can pick a recent file, then immediately
closes. No error message or anything, it just closes. I can no longer use revit on my computer now, and I have no idea
what is causing this.
Fri, Nov 30, 2012 at 3:14:04 AM | Revit Closes every time it loads
hugh
3.5 Stars: 4 Votes
Just off the wall - you may be loading an oddball addin that's malfunctioning.
Start off by searching your system for files with extension .addin
Hugh Adamson
www.hatchkit.com.au
Fri, Nov 30, 2012 at 7:30:03 AM | Revit Closes every time it loads
Make sure you have the latest update installed.
Revision cloud closes revit
Fri, Sep 28, 2012 at 10:47:53 AM
Revit Time Sheets or Revit Time Cards? or maybe at stop-watch plugin?
Tue, Mar 13, 2012 at 7:33:30 AM
adding existing loads to a panel schedule?
Thu, Mar 28, 2013 at 3:56:43 PM
Hanger Point Loads
Tue, Apr 7, 2015 at 8:00:03 AM
STRUCTURAL LOADS
Tue, Dec 21, 2004 at 5:18:59 PM
Page generation time: 1.8940
