143 Users Online (141 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> General Discussion >> Revit Project Management >> Mullions now showing on all plans?
Thu, Nov 29, 2012 at 4:24:30 AM | Mullions now showing on all plans?
EBrandon123
Would anyone please be able to tell me why my mullions on a standard revit storefront wall are not showing up on my ground floor plan, but are showing up fine on my first and second floor plans and also showing up fine on the 3d view. Thanks
Thu, Nov 29, 2012 at 6:55:29 AM | Mullions now showing on all plans?
Are they off in the VG of that view?
Is that CW hidden in that view?
Is that CW in a workset that is off in that view?
Is the CW in a phase that is not shown?
Is the ....?
Too little information
Thu, Nov 29, 2012 at 9:18:43 AM | Mullions now showing on all plans?
EBrandon123
Thank you for the reply. I had checked all of the above and was having no luck
So I have since changed the base offset of my curtain walling to 200mm (as that’s the height of my raised floor) and all the mullions suddenly appeared. I don't understand why this has happened?
Also maybe you could explain why when I set the base of the curtain walling store front to 200mm all the grid lines I deleted from the curtain walling on the ground floor to fit double doors reappeared and now all my double door have jumped back to fit in a 1500mm grid with a glazing panel beside?
Thu, Nov 29, 2012 at 9:46:32 AM | Mullions now showing on all plans?
A good learning point.  Your curtain wall has pre-defined grid spacings and probaby mullions and panels.  Unless that definition is individually unlocked for each item, it will always revert to the defined spacing.  We always unlock the entire CW by changing the type to one that has no definitions what-so-ever.  Then we make or adjustments to spacing - add doors - etc,
door and window mullions hidden in plan views
Wed, Oct 13, 2010 at 11:16:33 AM
Mullions not showing in plan
Mon, Apr 12, 2010 at 7:19:22 AM
Stairs and Area Plans...
Thu, Nov 29, 2007 at 4:40:40 PM
Adding mullions to a window
Wed, Dec 14, 2016 at 10:19:19 AM
Window not showing mullions in 3D
Sat, Jan 23, 2016 at 4:16:08 PM
Page generation time: 0.7659
