29 Posts No Rating |
Hi all,
I am trying to set up a view template for some exterior perspectives, and I want to have consistent lineweights, color, etc. Obviously, i should create a view template. However, I can't seem to figure out how to keep some things the same, but have different sun settings for different views. To clarify, I do not want to have one master sun setting that applies to all views, because it makes some in too much shadow. I'd like to keep things like visibility, lineweight, color, etc. consistent, but be able to adjust the sun settings on a view by view basis.
When I go to my Graphic Display Options in my view, I can't adjust the Sun setting, only the intensity of the sun, ambient light, and shadows.
Is it possible to make this adjustable by view?
Thanks,
JP
I believe that you can apply your view template that you want so that all of your line weights etc look the same then apply the <None> template, it will hold all of your previous settings but give you all of the control to change whatever you want back
Ok. The only problem with that is if I change any of the template settings, I'd have to reapply, then readjust my sun settings.
