60 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Revit Architecture 2013 - Moving Section Tag is Moving Referenced Detail
Tue, Nov 27, 2012 at 8:59:16 AM | Revit Architecture 2013 - Moving Section Tag is Moving Referenced Detail
Gobbler
Perplexed - Can anyone provide insite as to why my annotative detail moves in its view each time I move the section tag? The result is a detail that is no longer aligned at proper elevation / floor line. Thanks, Gobbler
Tue, Nov 27, 2012 at 9:14:57 AM | Revit Architecture 2013 - Moving Section Tag is Moving Referenced Detail
You are learning that you have to be careful with sections that are detailed.  You really should not move them.  Dimensions to objects get lost when the section is moved and the object is gone.  Its the same with other elements.
Tue, Nov 27, 2012 at 1:23:25 PM | Revit Architecture 2013 - Moving Section Tag is Moving Referenced Detail
Gobbler
Help me to understand the relation of the section tag to the objects in its view? Attached are 3 .pgn's:
"Sec Prior To Moving Tag" aligns with finish floor. After moving tag (down) in the elevation view, the "Sec After Moving Tag" no longer aligns with finish floor which is the unwanted result I am trying to understand,
I also notice the FF elevation registers as 2 9/16" which is the amount the sections were off when I re-aligned them. Is there a relation between the sec tag and the FF Level?
thanks, Gobbler
113746_Elev_with_Sec_Tag.PNG113746_Sec_View_After_Moving_Tag.PNG113746_Sec_View_Prior_to_Moving_Tag.PNG
Tue, Nov 27, 2012 at 2:18:29 PM | Revit Architecture 2013 - Moving Section Tag is Moving Referenced Detail
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Moving a section tag wont move a whole level.  Are you sure you re not grabbing a level line along with the section tag?  Unless I am missing something yet.
Tue, Nov 27, 2012 at 2:28:18 PM | Revit Architecture 2013 - Moving Section Tag is Moving Referenced Detail
Gobbler
Pretty sure I did not grab the level line when I moved the section tag.
Also, not all the annotation items moved - detail lines and regions moved but some components did not.
Something tells me there's a simple reason for this but it eludes me...
Tue, Nov 27, 2012 at 4:19:01 PM | Revit Architecture 2013 - Moving Section Tag is Moving Referenced Detail
You moved this using the move command.  That would explain your problem - you did not move it exactly horizontal.  Bump move it using the horizontal arrows.  The furher out you are the larger the "bump" and vice versa.
Wed, Nov 28, 2012 at 8:34:12 AM | Revit Architecture 2013 - Moving Section Tag is Moving Referenced Detail
Gobbler
Thanks, horiz arrows good advice.
Moving Elevations
Mon, Oct 11, 2010 at 2:45:26 PM
Section heads keep moving when view is cropped!
Fri, May 15, 2009 at 10:06:37 AM
custom section tag woes
Tue, Jul 24, 2012 at 4:47:03 PM
Moving Family Symbols without moving the family in one instance
Sat, Oct 12, 2013 at 1:01:07 AM
Roomtags keep moving in wall sections
Tue, May 8, 2007 at 6:39:50 PM
Page generation time: 2.4486
