61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Surface pattern on pad only shows up when it is highlighted.
I used "override graphics" to apply a horizontal line pattern to a pad that I have. The view range is set to 4' cut, top @ 7', bottom at -5'. The problem is, the pattern only shows up on the surface when I have the pad selected and it is highlighted in blue. As soon as it is deselected, the pattern disappears at all zoom levels. The detail level is set to fine, and I am on Hidden Line. Any ideas?
It may be a view scale problem. Change the scale to a larger scale to see if it then shows up. Revit will not show tight patterns at small view scales.
Surface Pattern of Material |
Wed, Aug 31, 2005 at 5:25:37 PM
Surface pattern |
Mon, Sep 10, 2007 at 11:18:01 AM
Topo surface/Building Pad problems b/w Existing and New Construction phases |
Sun, Feb 6, 2011 at 12:28:27 AM
Surface pattern to Topo surface |
Mon, Aug 19, 2013 at 10:50:10 PM
surface pattern hatch override |
Tue, Apr 4, 2006 at 12:28:50 PM
Members: | 2042200 | Objects: | 23026 | Forum Posts: | 152216 | Job Listings: | 3 |
